New Build
Nexrus
Gaming - The specs have no been released for SW:TOR but I'd like something that would potentially run it on mid grade settings.
Total budget is around 600
3) Where do you live?
USA - VA
Mobo, CPU, Ram, Graphics Card, Hard Drive, PS and possibly a CPU Fan
Just a case and case fans
6) Will you be overclocking?
No
22 inch
Anytime
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Something that will utilize my hardware very well and is reliable. I may SLI in the future but not at the moment.
Yes
Below is what I have came up with already. When choosing the below parts I took reviews and feedback in consideration heavily. I'm not great with troubleshooting so I prefer parts that have a history of reliability. I did not include a CPU fan or a PSU. I can't seem to choose a PSU.
I was hoping you could help me with that as well? Obviously I want something with more than enough juice and modular cables would be nice.
Should I fork out another 50 bucks and double my Memory to 8GB?
Should I use the stock amd CPU fan and heatsink? I dont know how they perform.
AMD Phenom II
A-DATA Gaming Series 4GB
EVGA FPB 768-P3-1360-TR GeForce GTX 460
ASUS M4A79XTD EVO AM3
Samsung 500GB
Prices as of 3/12/2011
Antec modular 650 watt power supply $80 shipped http://www.newegg.com/Product/Product.aspx?Item=N82E16817371021
cpu cooler $38 shipped http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&Tpk=cooler master 212
Phenom II x4 955 $140 shipped, save $20 from the 965 and use it on the cooler http://www.newegg.com/Product/Produ...808&cm_re=phenom_black-_-19-103-808-_-Product
your motherboard choice $119 shipped http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402
your memory choice $48 shipped http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409
6850 $175 shipped http://www.newegg.com/Product/Product.aspx?Item=N82E16814131374&cm_re=6850-_-14-131-374-_-Product
total $600 shipped, and you get a few rebates and gift cards you can later grab another 4GB ram with.
You won't find a current AMD board that does SLI. There is a software hack to enable it, but nvidia drivers have started scanning for the hack and borking your system.
All 7 components, $651.58 shipped, motherboard has $10 rebate, video card has $20 rebate, two $10 gift cards, that is $50 to get your 2nd set of ram if you still want to go 8GB.
Thanks for your advice.
Overall the components I picked was okay then? Is the only reason you replace the gcard I picked with the ATI is for future crossfire?
Not bad not bad. But still, needs improvement. Forget the old AMD 790 chipset. NO O/C? no need a cpu fan. Plus, no need for the A-Data RAM with heatspreaders also. Plus, you missed the optical drive.
What computer case will you be reusing?
Nope, no OC.
So then everything except the mobo looks good? What would you suggest?
I already have a optical drive and Ill be reusing an antec 900 2
Let's go with this. I agree with m_isom on the 955 cpu as the 965 won't add a noticeable difference.
Cpu AMD phenom II 955 + mobo Asus 870 combo - $226.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.613764
Power Supply Antec TP750 + Video Card Sapphire Radeon 6850 1GB combo - $249.98 ($15 MIR on video card)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.613140
Harddrive - Samsung F3 1TB for $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
RAM - G. Skill 4gb 2x2gb for $39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231396
Total: $571.94
Shipping: $4.84
Total: $576.78 + You receive $20 worth newegg promotional gift card.
Oh, BTW, forget about sli or crossfire. No need for only a 22" monitor. Better to have a mobo that supports SATA 6gb/s and USB 3.0
Yes, you had mentioned sli in the future, but your board selection only supported crossfire. I misread you are not overclocking, so a stock heatsink should be fine. There are ways to cut and seeing the 955 cpu is another $10 off and free shipping in today's newegg hot deals.
