New Build
legato
Sup guys & gals...Would like to build a new machine for 64b Win 7.
Greatly appreciate any feedback in advance!
Current running system:
200gb OS & apps drive, 320gb storage, 500gb storage, 200gb ext. storage, 500gb ext. storage
Asus A8N-E nForce4 Ultra Athlon 64(FX) Skt939 DDR ATX Motherboard
AMD Athlon 64 X2 4400+ Processor Socket 939 Retail
Corsair TWINX2048-3200C2PT 2GB (2X1GB) Kit DDR400
EVGA 01G-P3-N984-AR GeForce 9800 GT Akimbo Super Clocked 1GB DDR3
SB Audigy 2.0 (using this for my sub-par 2.1 speakers and onboard sound for my earphones)
Antec Performance One P180B
Corsair TX650W Power Supply
Windows XP Pro w/ sp3
web, email, word, excel, light gaming, anime, cad, revit
min $500, max <$1,000
3) Where do you live?
Hawaii
4) What exact parts do you need for that budget?
AMD CPU
memory
motherboard
(budget) soundcard with multiple outputs (please refer to #9)
5) If reusing any parts, what parts will you be reusing?
OCZ 60gb Agility SSD (have not installed, waiting on new build, and intending to use for OS & app drive only)
all existing int. and ext. hdd for storage
SB Audigy 2.0 (please refer to #9)
6) Will you be overclocking?
no, but would like to get a mobo & cpu combo that I can unlock cores :)
currently a 22" samsung 225bbw, plan to upgrade to a 24" down the road
~2weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
onboard lan
usb 2.0 (at least 6 on-board would be great)
onboard sound or if available a soundcard for dual outputs
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit? Windows XP Pro 32bit and Windows 7 64bit
Thanks in advance!
The cheapest I would go with:
Phenom II X4 925 + Gigabyte GA-770TA-UD3
G.Skill DDR3-1333 4GB (2 x 2GB)
~$300
If you want to make sure you spend atleast $500 (although the above build would do fine) you could go with:
i7 930 + Gigabyte X58A-UD3R
G.Skill DDR3-1600 6GB (3 x 2GB)
~$650
Or a middle ground:
Phenom II X6 1055t + Gigabyte GA-770TA-UD3
~$370
I would go with the first or last and then invest the extra cash in a better GPU or possibly a single 1TB drive and scrap all those random drives you have.
All modern motherboards have decent onboard audio and unless your an obsessive audiophile it should work fine.
Shadowssong: Thanks for the quick response! The AMD setups sound great :)
