New Build
tys90
Preface: I've built all my own computers and don't necessarily need a new computer but I know someone who could use my current computer if I get a new one so I'm thinking about building a newish one. I've given a large budget range but I basically want the greatest bang/buck in a system using overclocking.
I don't have the time anymore to do the thorough research I like to do so I'm asking for help. I'm not against buying used either, so if you suggest a used part put down est. price of the used part and please be realistic. Since my requirements are broad, I may throw in a little incentive for the person that comes up with a setup I like. Cheaper IS better if the performance is close.
  • Gaming 90%
  • $700-1000
3) Where do you live?
  • Iowa
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
  • Case and everything in it (no monitor, keyboard, etc)
  • Reusing all my peripherals
6) Will you be overclocking?
  • Yes, best bang/buck is what I want
  • Have a 22" and a 20"
  • Near future
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
  • Overclocking ability is #1, possible RAID #2, rest don't care
10) Do you already have a legit and reusable/transferable OS key/license?
  • Yes, XP and Windows 7
I think that covers everything
I'm resurrecting this thread because I'm once again looking at buying a computer, nothing has changed and I would appreciate the help
