I've been out of the loop for a while, but it's time for something new. Got a budget of roughly $1,000, and the primary use for the system will be gaming.
How's this build look?
Case: COOLER MASTER Centurion 590 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119152
PSU: CORSAIR CMPSU-750TX http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
CPU: e8400 + arctic freezer 7 hsf
MB: not sure... I want to be able to xfire 2 4850's at some point, but will only start with one, also want ability to oc since the cpu is supposed to be good for that, and I'm all about getting more for your money, leaning towards GIGABYTE GA-EP45T-DS3R http://www.newegg.com/Product/Product.aspx?Item=N82E16813128348 yay/nay?
GPU: hd 4850 http://www.newegg.com/Product/Product.aspx?Item=N82E16814102747
RAM: uncertain about this OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 http://www.newegg.com/Product/Product.aspx?Item=N82E16820227298 good for my needs?
HDD: SAMSUNG Spinpoint F1 HD753LJ 750GB 7200 RPM 32MB Cache SATA 3.0Gb/s http://www.newegg.com/Product/Product.aspx?Item=N82E16822152100
As far as the cpu goes, for a system primarily used for gaming, dual or quad core going to make a difference? I'm also looking at getting a 24" lcd in the not so distant future, what can I expect my gpu needs to be at higher resolutions? I've got a 20" or so lcd currently.
Thanks for any and all advice
