New Build
flashpoint603
Well, summer job is treatin' me well. Figured I'd upgrade my system. I would love some constructive criticism from you guys about my setup. (GAMING RIG)
evga 680i A1 mobo
e6600 conroe (plan to push this baby far. i hear the antec 900 provides awesome cooling)
corsair HX620W
crucial tracer 2gb kit (6400)
EVGA 8800gtx Superclock
150 WD Raptor
zalman 9700
xfi fatality sound card <~~~~(big difference from mobo sound? I will just be using seinhesser headphones)
Antec 900 Case
Dell 2407 A04rev
OS = Windows XP Pro
I'm not sure how much the tracer RAM costs but I wouldn't spend over $90 on a set of RAM since prices are so low. Also I've also heard that the X-fi extreme music is the sound card to get......also there are some good non-creative soundcards out now also....the names escape right now though.
Overall it is a damn good build.
Edit* what seins do you use???.....may be you could through in a good headphone amp which will def make you sound better or even upgrade you cans.
$119 on tigerdirect for the RAM kit
im actually using icemat siberias atm(payed their dues. duct tape, shorting out, cracking). my uncle is a sennheiser dealer so i was gonna get some HD650 from him for practically nothing.
X-Fi is hellish to deal with at times right now. I'd stick with onboard for a while or go non-Creative. This is coming from a long time Soundblaster owner (Soundblaster, 2, AWE32, Audigy) and current X-Fi owner... that hates their card. Check the Creative forums and you'll see I'm not alone in this. Vista drivers are crap but at least get updated, XP drivers work when they work but sometimes have major issues, and have not been updated in months. Build quality on the entire range of cards is questionable.
If you do go X-Fi don't waste money on the Fatality card. Get an XtremeMusic -- same DSP and all, just no stupid "x-ram" you will probably never use and no "Live Drive" or whatever they're calling it now.
The X-Meridian is a card to look in it.
That Zalman HSF gives kind of "blah" performance -- a Scythe Ninja Plus Rev B, Sunbeam Tuniq Tower, or Thermalright Ultra 120 Extreme will treat you much better.
If you plan to go SLI at any point get a beefier PSU. That will handle a single GTX just fine, but 2 over time may kill it. The PC Power and Cooling Silencer 750 Quad or any higher rating Thermaltake Toughpower (700+ watts) will do fine. Silverstone is also an option.
If you don't plan to go SLI a P35 based motherboard may make more sense, since that will allow you to get one of the 45nm Peryn chips later on. That said, the board you're looking at "unofficially" supports Peryn already. You could save about $100 going with the Gigabyte DS3 or something, though.
Awesome pointers. I dont really plan to go into sli atm. I know as soon as I buy a second card Nvidia will be turn around and release the 8950gx2. I do however wish to overclock quite a bit and have read that the 680's are good for that.
Surely 1 8800gtx superclock can handle most games @ 1920x1200 with eye candy. no?
It should. For how long, I don't know.
By "go SLI" I mean /ever/. It makes far more sense to spend $50 now if you think you may do so in 6 months for the ability than another $200+ on a new PSU then.
ill just say no to sli right now and assume this card will last me until the 8900 series when i wil consider Sli. I already have the power supply and case. Using it with my old internals. I was assured that the 620watt corsair could do SLI on the big cards.
Yah, a single GTX should be fine. Though, for that high res, I'd keep SLI as an option, lol. Though, you could drop it down to a 650i SLI chipset instead if you need to save some cash. It will still provide enough bandwidth for two cards to drive a 1920x1200 screen. I still think there will always be a better single card solution over SLI, even for that high res. When you get into the 30" LCD range... an SLI setup is needed for gaming, IMO.
Drop the Zalman, go for the Tuniq or Thermalright, since you have the nine hundred.
The Corsair 620W should be fine, even for GTXs in SLI.
Drop the X-Fi, look into the Auzentech cards... like the one Silent-Circuit mentioned.
