New Build, Won't Turn On
Trendy
I'm having a strange problem. I just did a new build, got everything generally hooked up last night, plugged everything in and hit the power button and it worked.
Then when I hook it up to my monitor to install the OS, I realize only one of my two optical drives show up during post. I went to bed and this morning I poped open the side and saw that both drives are set to slave, easy fix eh?
Well, I switch the dip to master, put the case side back in place, and then. . . the PC won't start. I get a clicking sound from the PSU, that's about it.
Any ideas? I think it's the PSU, but I'm leaving to take an SAT in half an hour and don't have time to switch it out for a test.
Oh, the PSU is CORSAIR HX620w: http://www.newegg.com/Product/Product.asp?Item=N82E16817139002
Probably a PSU, 620 watt is pretty big unless you're running a ton of drives and have a (couple) highend video card(s).
What's the rest of your system?
Unplug something and turn it on to see if it works.
Actually, I'm now completely confused. I was almost sure it was the PSU and it had just given out, but upon returning home I was going to show my brother the sound it had been making and to my utter disbelief, it turned on and is now working just fine.
What I think may have happened is when I went to move my PC into the middle of the room I put pressure on the back of the PSU and may have slightly bent the back grate in, touching some of the components that are located quite close to the metal casing, causing it to just short out whenever I attempted to turn it on. Letting it sit for the past 5 hours must have allowed it to bend back out, but I'm not sure. I have a huge ass full tower case that weighs a good 50 pounds (not kidding), it's a monster.
Anywho, to answer your question, I have a Gigabyte P965, Intel Core 2 Duo E6600, 1gig of G.Skill DDR2-800 (5-5-5-15 timing now, but supposed to be 4-4-4-12 after a bios update), XFX GeForce 7900GT 256MB, Zalman Heatsink/Fan, and the usual HDDs, optical drives, and such.
