Evening all,
Im in need of your help, ive just put together comp with the following parts
Q6600
Gigabyte GA-EP45-DQ6 http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2831
G.Skill 2 x 2GB PC2-6400 http://www.newegg.com/Product/Produ...-Memory+(Desktop+Memory)-_-G.SKILL-_-20231122
8800GTX
Zalman CNPS9500 CPU Cooler
Problem is it wont turn on! When i press the power button it starts for around 3 secs, gives 1 post beep then turns off. Then it seems to cycle through this process endlessly...?
Ive tried re-seating the CPU, differrent combinations of memory sticks (1 in, both in, swapped etc) and a different GPU (X1900XTX) with the same result.
There are onboard LED's to use as diagnostics. 1 is a long bar of LED's to indicate CPU loading (4 green, 4 orange, 4 red in a long line). When the power buttons is pressed these all light up indicating full load i think.
Could there be a problem with the CPU? Is it the board? All parts are new except the GPU's and Zalman.
Is there something im missing?
Please help!
Q6600
8800GTX
Please help!
