Zorachus
- Dec 17, 2006
I'm so frustrated and tired after redoing doing my system and it won't friggin post.
My old system is in my signature, I'm reusing most of those parts which all work perfectly.
Only new stuff I bought was:
-New Lian Li A3 case
-9800X3D CPU
-B850 Gigabyte motherboard
-WD850 nvme drive
Everything else is reused from my current build, which is:
RTX-4080 FE
32gb DDR5 memory
Seasonic 1300w PSU
Kraken Z73 cooler
Ok I take the parts out of my old case. Then setup the new case, install the motherboard and coolers and PSU. Wow this case is much smaller and cramped everything tight in there, but it all fits and I love the size and smaller form factor.
Finally get it all together and wired up and everything connected. I do a quick power button press and ever turns on and lights up.
Ok good
I bring the new case down to my computer room, plug in
the monitor and keyboard + mouse, etc... turn it on again, everything lights up, all fans and video card working.
Monitor is turned on, it shows display port on the screen, and nothing else. Waiting ...
2 minutes goes by, monitor is dark, but system running.
I turn off the computer and restart it. Same thing monitor just black besides showing the display port signal for a few seconds on screen and nothing else. Keyboard doesn't light up or anything.
I turn open the case and check that memory is seated properly. I take video card and reseat it. I took the drive out and tested it, etc... everything was in correctly nice and snug.
Turn it on again, same thing. Computer powers up and all fans and lights working, but nothing else, it won't post or even go to BIOS.
Ugh...worked on this all afternoon/ evening and I just can't figure this out. And I've built gaming rigs for myself every few years for the past 20+ years and they always work.
One off thing I couldn't get right was the case wire to the motherboard ( Fpnl ) front panel powe that connects to the little prongs on the corner of the mobo didn't seem to plug in per the diagram on the instructions, as if a capacitor was in the way a bit. I had to move it a little further for on that prong part. But it just work because with I press the power button on the case it turns on it off.
Anyways, what could the use be?
-9800X3D CPU
-WD850 nvme drive
RTX-4080 FE
32gb DDR5 memory
Seasonic 1300w PSU
Kraken Z73 cooler
Ok good
