I just went through the FAQ:
http://www.hardforum.com/showthread.php?t=1349426
And got to the bottom without any luck (If it won't POST, try different RAM slots. If it still won't post, pull out the ram (so no ram in the system) and listen for error beeps. If none, pull the vidcard and listen for error beeps. If none, re-seat the CPU and HSF, then try again. Report back with results if you're still having issues.)
Here is my current build (Mini ITX)
- Intel E5200 CPU
- ZOTAC NF610I-D-E Nvidia GeForce 7050 Mini ITX Motherboard
- Crucial 2 x 1GB DDR2 667 RAM
- Apex MI-008 mITX Tower Case w/ Allied 250W Power Supply w/FS
All purchased from the newegg (and reusing an HDD). I get no beeps and nothing on screen. How do I tell if it's the CPU/ Powersupply/ or Motherboard?
- Intel E5200 CPU
