New Build won't boot
stitchmanz
I just built a PC and when I turned it on for the first time I got nothing. It powered up, all the fans were running, but nothing showed on the monitor.
Here are the components all from Newegg. I’ll be installing Windows 7 Pro once I get that far.
Western Digital WD Black WD2002FAEX 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
SAPPHIRE 100352-2L Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Crucial M4 CT256M4SSD2 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C10D-16GAB
Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770K
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/FM2/AM3+
Corsair Carbide Series 500R White Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
SeaSonic X750 Gold 750W ATX12V V2.3/EPS 12V V2.91 SLI Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
The monitor is a Samsung S27A350H
Here is a picture of a cable that I don’t know what it belongs to, if it’s even used at all:
Can you please give me some suggestions on where I can start to figure out the problem?
Thank you very much
Jerry
Did you computer produce any beeps and if so how many?
Are you sure you plugged it into the video card? If so double check that it's seated properly on the motherboard and plugged in comfortably. Did you try to plug it directly into the motherboard's connector instead of the video card or vice versa? Sounds like the mobo is getting the power, is the monitor showing power at all (should still power on if getting power)?
Did you computer produce any beeps and if so how many? - there were no beeps
Are you sure you plugged it into the video card? - yes, the fans are spinning
If so double check that it's seated properly on the motherboard and plugged in comfortably. - i removed the video card and placed it ina different slot, same thing happens
Did you try to plug it directly into the motherboard's connector instead of the video card or vice versa? - i'm not sure how to do that
Sounds like the mobo is getting the power, is the monitor showing power at all (should still power on if getting power)? - the monitor show no connection, the power is on (light is blinking)
thank you
jerry
I'm such an idiot. I didn't have the power to the CPU plugged in.
I still am not getting a beep when booting up though, but windows is now installing
Jerry
Hi Jerry, try rotating your speaker connector 180. Sounds it it isn't polarized.
