Not sure if this is the right spot for this but....
I'm making the switch back to Intel with a new 2600K and ASUS P8Z68-V PRO. I also bought a OCZ 120GB Vertex 3 SSD.
Here's my plan...
Make the SSD my boot drive with the essentials installed. I also have 2 matching 1TB Western Digital hard drives. I would like turn them into a RAID 0 array and partition them into a couple of separate drives.
My plan is to install the SSD first, and get windows all patched up, my antivirus etc. installed. Then, add the 2 WD's in RAID 0.
Here's the question, do I set the BIOS to RAID from the beginning with just the SSD or can I set up the RAID array after the SSD is up and running.
Also, should I leave the windows swap file on the SSD or on the RAID?
If anyone can walk me through the best process to make this work, I'd appreciate it!
Here's my plan...
