New build with some leftovers.
2004raptor
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc. Moderate gaming, Some photo/video editing. General computing.
2) What's your budget? Are tax and shipping included? $575 total.
3) Where do you live? GA
4) What exact parts do you need for that budget? CPU, mobo, Video Card, Heatsink/Fan.
5) If reusing any parts, what parts will you be reusing? Antec P182, 150GB RaptorX, 500GB Seagate, Antec Mx-1 with 1TB Samsung SATA, Corsair HX620 PS, DVD burner (SATA), Dell 24" LCD (1920 x 1200), 2x4GB G.Skill Ripjaws DDR3.
6) Will you be overclocking? I'd like the option to.
7) What size monitor do you have and/or plan to have? 24"Dell Ultrasharp.
8) When do you plan on building/buying the PC? 2-3 weeks.
9) What features do you need in a motherboard? USB 3, eSATA
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? W7 x64.
A couple of notes.
I am pretty convinced to go Sandy Bridge so the 2500k is what I would like.
The motherboard I was kinda leaning towards is the ASRock extreme4. I think the Pro3 also has most of the same features.
The RAM I listed above was more of an impulse buy when it was a shellshocker on newegg. The only thing I am cautious on is that it has the taller heatspreaders. Hoping this won't be an issue with whatever heatsink/fan I end up with.
From all the recommendations I've read, the CM Hyper 212+ seems like a good choice if it will fit over the RAM w/out issue.
As far as video cards go, I am really torn. I see some decent ATI deals but I generally go nvidia. I like the 560Ti.
Not enough $ to go SSD at this time.
So, any suggestions?
Which games are you playing? Which programs are you using for photo/video editing?
How old is the HX620?
The main games I play are the COD series. Not sure if there's anything new coming out similar but I like those type of games.
Photo editing like light photoshop but also managing tons of photos. Not sure of what program I want to use for that. I actually meant to put Video encoding, etc. I rip dvd's a good bit here and there.
The 620 is pretty old. I have confidence it can handle the above listed system though. Do you see an issue?
I would think you should be fine with the psu unless you wanted to go sli in the future. I would recommend nvidia over ati right now, you get better performance per $ on ati right now but the drivers have been pretty crappy for my 6850 at the moment so I think nvidia is the better overall buy.
Here's a nice combo on newegg, the board is only $60 after rebate. I dont know if it has all the features you want though. 2500k + ecs p67 $284 after rebate. The next cheapest p67 board on newegg is $124. Edit: No esata so probably wont work for you since that is listed in your features.
Galaxy gtx 560ti $209 after rebate.
Before rebates that is $544, you'd get $50 back in 2 different rebates. If you swap out for the next cheapest p67 board that would put you over your limit.
That gives you some money to spare after the rebates if you want a new psu or I would recommend the spare change go to a ssd you will really see the difference.
When are you going to start buying the parts? Next week (actually, starting on Friday), NewEgg will have some different combo deals for the month of April.
Are you planning on playing some of the newer games arriving soon like Crysis 2? I ask because I believe that the GTX 560Ti may not be enough for excellent frame rates at high visual settings. However, if you go towards a high-end video card like the HD 6950, you won't be able to go Sandy Bridge unless you increase your budget.
I believe that you should replace your power supply if it's over three years old. In doing so, you eliminate the possibility that the power supply has degraded to the point that it can no longer handle the full load coming from an overclocked system and a high-end video card. However, given your meager budget, I'm not going to focus on a new power supply right now.
Here's a build for right now focused around the i5-2500k:
$252 - Intel Core i5 2500k & Cooler Master Hyper 212 Plus combo
$135 - MSI P67A-G43
$175 - XFX HD-685X-ZNFC HD 6850
$562 - Subtotal (not including shipping, taxes, or rebates)
Simply put, I don't trust ECS boards to be good overclockers, so I went with MSI. It seems like many of the inexpensive (sub-$200) Asus and Gigabyte boards are having problems at this point in time, and the board that I chose was cheaper than the cheapest Asus and Gigabyte alternatives. I chose the HD 6850 to keep everything under your $575 limit, but shipping charges may push things over.
Now here's one built around the HD 6950:
$427 - AMD Phenom II X6 1055T & Gigabyte GV-R695D5-2GD-B HD 6950 2GB combo
$100 - Asus M4A87TD EVO
$35 - Cooler Master Hyper 212 Plus
The X6 1055T is a good overclocker despite having a locked CPU multiplier (unlike the Black Edition AMD processors). The processor also has a combo deal with the motherboard, which would allow you to choose a different video card (if you so desire; but AMD currently has the bang-per-buck performance crown, so I don't recommend an Nvidia card at this time).
Neither board comes with built-in eSATA, but you can buy a cheap expansion port adapter that turns two of your internal SATA ports into eSATA ports.
No problems with drivers on my 6850 & I got it day 1 (ordered 8 minutes after they went on sale at newegg)
Thanks for the options so far.
I'm gonna stick it out with this Power Supply unless I have issues during the install. Then I'll grab another one.
My plan is to order items by ~4/8 or so. Maybe a day or two earlier or later but around then. By then I'm hoping newegg does have some decent combos or shellshockers.
I'll kick around the idea of ATI and continue looking at reviews.
From what I've read intel is the way to go as far as my processor thou. I am not being stubborn but I don't think I'll budge on that front.
I hadn't noticed that "combo" deal for the 212 and 2500k so thanks for mentioning it. BUt I double checked Amazon and it would still be cheaper through them becasue newegg charges ~$7.xx shipping.
Keep the suggestions coming. Thanks.
I dontt hink you will have any issues with that corsair psu. there pretty solid.
Games wise they are fine but my monitor wont come out of sleep on the newest drivers. If I have a second screen hooked up, like my tv it does some funky things with certain apps/games in fullscreen depending on the drivers, the newest set fixed most of the problems but gave me the stupid sleep problem. It's the non gaming quirks that bother me.
