New build - Web Dev & General Use
Perrupa
- Web development
- Some light photo editing and Illustrator work
- The usual movies/browsing/chatting/etc...
Budget isn't set in stone but lets try and keep it under $800?
Toronto, ON. Canada
Case (I'm looking at Fractal design cases...)
CPU
Mobo
Ram
SSD
Video card if integrated cards aren't up to snuff
PSU - OCZ Stealth Stream 2 600W
HSF - Antex Kuhler H20 620
6) Will you be overclocking?
If I can do so quietly
Dell 27" @ 2560 x 1440
Over the next month. Unless there's something to wait for?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Onboard video
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
64bit windows (I have msdn from a conference)
Oh, forgot to mention: I'm hoping to run this as quiet as possible, so anything else I should take into consideration would be great to know. Thanks again. My last build you guys helped me with went awesome :)
What applications in particular will you be running?
Would you also be running local IIS/Apache instances and/or VM's on this machine?
Edit: Since this is a dev machine, would there be any (near?) future interest in a second monitor?
Did dual 22" monitors and I prefer working on my 27" for now. No real need for dual monitors.
WAMP stack and VMs for cross "browser" testing and my IDE changes depending on the language but it's usually PHP Storm or Sublime Text, neither of which is pretty heavy. But I don't restart my machine a lot and run a lot of stuff at once so I was thinking 16GB of RAM is reasonable?
16 GB of RAM should be plenty for VMs, the OS, and the dev tools. In fact, 8 GB could be enough -- it just depends on the VMs themselves. But 16 GB is a safe number.
I would recommend getting a SSD for your OS and dev tools, and either a SSD or a fast mechanical drive (or two) to run your VMs from. For local dev/testing with VMs, having a separate disk (or disk array) to run the VMs from is a huge performance boost and reduces the time between local debug and simulated remote testing.
I'll defer any hardware recommendations to the more experienced members frequenting this forum.
