New Build Very Shortly
fantomau
I'm going to be building a new system very soon with the following:
Motherboard: ABit IP35 Pro
CPU: Intel Core 2 Duo E6750
Ram: Crucial Ballistix PC-6400 Ram (2gigs) (Already ordered)
PSU: Corsair HX620 PSU or a Ultra X3 600W (I like that all the cables (Mobo cable as well) is modular with flexforce)
Videocard: EVGA Geforce 8800GTS 320meg
Heatsink: Zalman CNPS9500LED HS/F (Already have)
OS: XP Pro (Wont use Vista anytime soon)
(Already have 4 HDs (2 external ide and 1 internal ide and 1 internal sata), DVD Burner and viewsonic monitor)
I'm probably going to get a new case as well, But havent decided on which just yet, But these are the ones I'm considering:
Silverstone TJ07
Lian Li PC-V2000Plus II
Lian Li PC-A70B
Cooler Master Cosmos
Cooler Master Stacker 830 EVO (Version w/o the side panel fans from Performance-pcs)
Opinions/Suggestions please.
Build list looks good. I'd go for the Corsair 620 watt, or even their 520 watt modular model for the PSU.
As for the case, I'm in the camp that says Silverstone is best. However, the TJ-07 had a few things about it which ultimately turned me off. First, reviews I've read fault the case for having a loud rattle in some instances, and several reviews point to minor warping on the side panels. Ultimately I went with the TJ-09. While a bit smaller, I've found it to ultimately be a better design. I particularly like the setup around the hard disk cages (with the fan sitting between them and the motherboard space, as well as the intake vents around the graphic cards. The only instances in which I'd recommend a 07 over an 09 is if you're building a rig with a redundant PSU or want a water cooling setup with an internal radiator. Otherwise I think the TJ-09/10 is a better bet.
High end Lian Li's are also well known and highly praised as great cases. If you prefer their styling over Silverstone's, by all means go with them. I personally think Silverstone and high end Lian Li cases are better than the Stacker 830 series, which has always come off to me as cheap (in quality) for its price.
Mark.
I say if you're going for the Lian-li, get the v1200plus II instead.
Unless you really want the bigger variant.
The 1200plus is still large enough imo.
And I definitely think lian-li makes one of the best cases, but does come at a premium of course..
You get what you pay for..
Thanx.
As for paying a premium, Thats true, But the TJ07 w/ window costs more than any of those, Especially at NewEgg (I think $329).
I've also read reviews of the TJ07 and the removable mobo tray being on a track and that it had the tendencies to rattle, Due to the fact that it wasnt secured and the side mesh being held on by bent metal tabs.
I do like how the TJ07s has the 2 sections separated.
The Cosmos I really think looks very sharp and I like the way you can hide cables.
The Lian Li PC-V2000Plus II has always been the case I've wanted, But the 1 thing that I dont like is that the panel is on the right side, Meaning I'd have to put my system on the left side of my desk, Because if it was on the right side, Wouldnt be able to see the led fans and cold cathodes etc. But I guess being on the left side isnt that big of deal.
I've opted out on the stacker series myself, As it does look a tad bit cheap.
I don't know too much about the Cosmos considering that it just came out. However, from what I've read and seen, it looks very promising. Very stylish, and I like that it actually includes the fans.
Mark.
FYI the HX620 from Corsair uses cables identical to the FlexForce cables of the X3 Ultra.
I thought the TJ-07 has been newly revised? I like the new version better than the old one.
The only stacker I like is the original TC01. It feels like a tank to me, lol, so I like how solid it feels.
I'd ditch that Zalman for the Tuniq Tower instead. The Tuniq is $47 @ svc.com.
Just so ya know, The Corsair may have the same type of molex, pcie, sata flat cables like the Ultra, But it doesnt have the same flat motherboard cables like the Ultra, Making it easier to hide the main cables as well as the rest and all cables are modular. Whereas the Corsairs main connectors arent modular, But mixed (Main connectors are wired and the rest modular).
Heres a pic of the cables of the Ultra X3:
http://enthusiast.hardocp.com/image.html?image=MTE4NzU1NDcyNXNzN0JabzRNakNfMl8xMF9sLmpwZw==
Even discussed on here: http://www.hardforum.com/showthread.php?t=1216720
Every version of the X3 (600 to 1600w) has the same cables.
Also the Ultra is rated at 85% efficient and uses a single 12v rail.
New version of the TJ07? I've only seen 1 version of it, And they all look the same.
As for the Zalman, I got it because of all the really good reviews I read. If after I install it, It doesnt work good, Then I will consider something else.
Yeah, I like the Cosmos myself as well.
ahh, then go with the Ultra. I don't care if I can see a few cables in my system, lol.
hm... guess I was wrong about the tj-07. I got it confused with the tj-06.
The zalman is easy to install, but its overpriced, imo.
If you dont mind me asking, Whats so bad about the Zalman coolers?
Dont get me wrong, The Tuniq Tower looks very nice, But I saw it installed in a case and it was slightly tilted and thats what kind of scared me off from it, Being that its so heavy and huge.
I only paid $49 for the Zalman, And I see the Tuniq Tower is $70 and $73 w/ shipping from NewEgg.
