New build thoughts?
mongoosenco
Will be using this for gaming. FPS, RPG games mostly, and video encoding/storing my dvd/bluray libray.
Budget is approximately 2800 including tax and shipping.
United States Sierra Vista, AZ
CPU, Case, Cooler, SSD/HDDs, Video Card, Blu ray Drive, Memory, Power Supply, Motherboard
Just a mouse keyboard and monitor. Razer Lachesis, Logitech Keyboard, Samsung XL2370 monitor
6) Will you be overclocking? Yes
1920x1080 23 inch
Within a month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Would like wireless ac on the motherboard since my desktop will be wireless and I will be upgrading my network setup soon.
I do have a windows 7 license I could reuse 64 bit, but may go with windows 8.
So far this is what I am looking at:
Intel Core i7-4770K 3.5GHz Quad-Core Processor
Corsair H80i 77.0 CFM Liquid CPU Cooler - I was also looking at h100i, but I know it may not fit in fractal R4
Asus Z87-DELUXE ATX LGA1150 Motherboard
G.Skill Trident X 16GB (2 x 8GB) DDR3-1600 Memor
Samsung 840 Pro Series 256GB 2.5" Solid State Disk
3 Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive
EVGA GeForce GTX 780 3GB Video Card - Do plan on upgrading my monitor setup in the future for higher resolution.
Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case
SeaSonic 750W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply
Lite-On IHBS312-98 Blu-Ray/DVD/CD Writer
Does this all seem decent?
What version of Windows 7 do you have? Why are you considering Windows 8?
What does the G.Skill Trident X has that the G.Skill Ares doesn't?
I recommend dropping one of the 3TB Seagate HDDs and doubling the capacity of the Samsung 840 Pro to 512GB.
You should also consider the 4GB GTX 770 over the GTX 780 -- that is, if you play more RPGs than FPSes.
Does the Lite-On Blu-ray burner come with media software?
I have windows 7 ultimate 64 bit.
Trident had better timings, but other than that nothing.
I wouldn't mind increasing the size on the SSD, but I have a lot of movies, music and stuff to store. So I will have to see about that one.
I guess I will need to compare the performance of the GTX 770 vs 780 and look at the price differences.
I do not think it does come with media software, but I plan on using makemkv to create files I can stream so I probably be ok without the software.
Which Seasonic 750W PSU are you talking about?
Does anyone know how hard it would be or if it would be possible to get the h100i installed in that case with that motherboard?
Well as noted by Tiraides, drop the RAM down to the cheaper Ares RAM as the lower timings means virtually nothing in real world performance.
As for the PSU, it's not a bad choice.
I have that case, MB and an H100i setting on the bench, it looks like it will fit with one pair of fans. I wasn't going to use these there components for the same build but I could mock it up for test fit if no one else knows the answer.
MB and H100i are for a i7 4770k build in Define XL R2. My R4 case has a Z77 Sabertooth and i7 3770 in it currently.
What do you think of the define xl r2 compared to the r4? I did look at the XL, but wanted to try a mid tower setup this time around.
The XL is much larger, but still might not have enough room for the H100i with four fans. The XL comes with one more case fan and if you were going to run 2 video cards the bottom drive cage will clear easily were as the R4 could have clearance problems with certain dual video card set ups.
In addition the XL I have is slightly off as the MB does not line up with the IO plate very well, whereas both the R4s I've built had zero issues.
I would definitely be using only 2 fans on a h100i setup. Thanks for the info on the cases. I will stick with the R4 for this build.
Well I bought everything and decided to go with this. Everything should be here today.
G.Skill Ares X 16GB (2 x 8GB) DDR3-1600 Memor
Samsung 840 Pro Series 512GB 2.5" Solid State Disk
4 Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive
Galaxy GeForce GTX 780 3GB Video Card
SeaSonic 850W 80 PLUS Gold Certified X850
Pioneer Blu-Ray/DVD/CD Writer
Can't wait to get it up and running later today.
Thanks for the suggestions everyone.
You will probably need to add two case fans, a second intake fan at the front for the drive cage and an intake fan at the bottom of the case, also take the sound proofing material out of the top of the case to let it exhaust hot air.
I forgot to mention. I did pick up some extra fans so I will be able to increase the airflow. I was going to put two fans as exhaust on the top and add the fans you suggested for intake.
You only have 4 chassis fan headers that are controllable but you can use the case's built in fan control switch for the bottom case intake fan.
