New build, suggestions?
Lurk
A friend of mine is ordering these parts for his system soon.. he can't post since his account hasn't been reviewed yet, so I'm posting for him.
CPU: Intel Core 2 Duo E6600 Conroe 2.4GHz 4M sharing L2 Cache LGA 775 Processor
RAM: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
Vid card: eVGA 768-P2-N831-AR GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 HDCP Video Card
Mobo: eVGA 122-CK-NF68-AR Socket T (LGA 775) NVIDIA nForce 680i SLI ATX Intel Motherboard
HDD: Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive
PSU: CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply 100 - 240 V UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick
Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
Sound Card: Creative Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series 70SB046A00000 7.1 Channels 24-bit 192KHz PCI Interface
Any suggestions?
get better ram. that corsair standard xms stuff has zero OC headroom. If you only like corsair, then get at least the 8500 dominators. the 6400c4d no longer use the good micron d9 chips.
otherwise perfect.
if your friend wants sli, tell him he may need a larger PSU, but it is hard to find a good modular psu that powers 2 8800gtx.
No aftermarket CPU Cooling? If he wants to OC, then go for the Tuniq Tower, 9700, or Ninja Plus. Also, go with the Patriot sticks or Crucial sticks that use the good micron chips instead of Corsair -- if he plans on OC'ing. If not OC'ing, go with Corsair ValueSelect DDR2-667 2GB instead.
