StudioXcel
- Aug 23, 2006
I'm putting together a rig that will last me for a few years (with minor upgrades) and I want to check with you guys on the parts before I purchase it. Any suggestions or comments are welcome.
1 x Antec P150 (430W Neo PSU)
1 x Asus P5B-E (may go with the P5B Deluxe if I have a few extra dollars)
1 x E6400
1 x Scythe Infinity
1 x OCZ Platinum XTC DDR2-800 2GB 4-5-4-15 Dual Channel kit
1 x EVGA 7900 GS
1 x Zalman VF900-CU
4 x WD Caviar SE16 250GB (possibly cut back to 2 drives) (running in RAID 0)
1 x Lite-on DVD burner (black)
1 x Hauppauge PVR-150 OEM
Well, that's it. As is, it totals around $1960 (Canadian) after shipping and taxes. I plan on OCing this guy to around 3.5Ghz, memory at DDR2-900 (approx), and OCing the 7900 GS a little bit. The VGA heatsink is mostly for noise reduction.
My biggest worry is with the power supply. Will it be enough to provide the power for 4 hard drives, the 7900 GS, and OCed proc and memory? If not, will it be fine with only 2 hard drives? Voltage stability is very important for pushing CPU to the max (not that I'll run it that high all the time). Or should I sell the PSU and get something a little beefier?
Again, all suggestions are welcome, as I won't be ordering until around boxing day or a little later. Thanks!!
1 x E6400
1 x Scythe Infinity
1 x EVGA 7900 GS
1 x Zalman VF900-CU
