New Build...Suggestions Appreciated!
Tnaqvsld
Ok, building a new system and working with a $1000 budget give or take a little. After some consideration here is what I've come up with....
CPU: Intel® Core 2 Duo E6400
Motherboard: GIGABYTE GA-965P-S3
RAM: G.SKILL 2GB
Video Card:SAPPHIRE100176L Radeon X1950PRO 256MB
Hard Drive:Seagate Barracuda 160GB
CD/DVD Drive:LITE-ON Combo Drive
CPU Air Cooler:ZALMAN CNPS 9700
Case:Antec PERFORMANCE TX TX1050B
The case comes with that 500w power supply...that should be alright shouldn't it? The memory is currently sold out I believe so I guess I need to find something that compares price wise. Everything comes to $1000 and change before tax and stuff, but how does it look...Thanks for the help!
Looks good. I have the DS3 board with that same CPU and RAM. I added a Scythe Ninja to keep it cool while at 3.2Ghz (30° idle/50° load). That 9700 is pricey, but hey, its one of the best.
$40 - Scythe SCNJ-1100P 120mm CPU HSF
The SP2.0 500W is ok, I have two of them. They both work great, no cap issues. There was a bad run of Antec PSUs, so if the one you get is bad, they'll RMA it quickly. Also, the SATA Lite-On DVD burner is the same price, but OOS. I'd wait til it gets back in stock, though.
What size monitor do you have? What games do you play and at what resolution?
Right now I'm just using a older KDS 17" lcd but will be purchasing a new monitor once I get this new machine built. I'm looking at either a 20" or 22" widescreen but still trying to make a decision on one. As far as gaming goes I'm not big into it right now, mainly due to the limitations of my current pc, but definitely want to do more with the new build.
