Morning all,
Ok so im putting together the following parts:-
Q6600
Gigabyte Mobo GA-EP45-DQ6
2 x 2gb G.Skill
8800GTX
Tagan 600w PSU
I had a few problems with the mobo which Gigabyte fixed by way of a bios update.
Ive ran a few benchtests and all seems ok. First with just cpu and ram, posted fine, then with gpu and it booted ok on screen and stopped when asking for a Boot disk. So i connected my harddrive which already has a copy of XP on it with the thinking that im just going to wipe the disk and reinstall windows. I also connected a wireless usb kepboard and mouse.
First problem was the usb keyboard would register so i couldnt get into the bios to change the boot up to cd. So after the comp tried to start windows and failed it reset. I eventually got the keyboard working and managed to get into the bios and changed the boot settings. After saving & restarting the comp doesnt try booting from the cd though, it just gets past the initial Gigabyte screen and resets, it does this over an over.
Second problem is i cant get the keyboard to work anymore? The usb receiver is picking up keyboard as the wireless light is flashing but i cant get into the bios again, or any other menu. Is it best to start with a wired keyboard? The last time i built a comp this keyboard setup worked ok?
Any help will be appreciated, cheers.
Q6600
2 x 2gb G.Skill
8800GTX
Tagan 600w PSU
