Gaming, photoshop
$350 (no tax/shipping)
3) Where do you live?
Indiana
CPU, MOBO, RAM, HSF, case (see below), hsf?
HDDs, Video Card (found a cheap GTX460), PSU, and case. I have an h50 push/pull if needed.
6) Will you be overclocking?
if possible but not essential
24"
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
RAID, USB3.0
I have this. Win7 64 Bit
Well with Sandy Bridge problems, I have to put that on hold. Looking at getting a cheaper computer to hold me over until something newer comes out that doesn't have any problems. No big deal to wait a little while. I've been wanting to build a small tower for a little while now, either micro atx or mini itx. This computer will eventually move over to just being hooked up to a 40" LED. For the time being it will serve as my main computer. Just need help figuring out something cheaper. I don't need cutting edge, and if it can be cheaper awesome, if not 350 is fine before taxes and shipping. Also if you can add in a small tower i'd be really appreciative. Thank you for the help again, sorry for having to post about another build. Didn't see this coming when I woke up this morning.
Gaming, photoshop
Indiana
24"
ASAP
RAID, USB3.0
