New build set up
Stanley14
Hi all
So I have nearly completed a new build using 2x 360mm (45mm thick) rads..
My loop is pump to gpu.. then into first rad. Out of first rad into motherboard VRM’s, then into processor, then into second rad and back into reservoir..
Does this seem ok or would I face any issues with this loop config ??
I’m kind of thinking it proberly does Not matter where the rads go, but I like the idea of having one in between the GPU and CPU
thats fine, doesnt really matter once water temp equalizes. mine goes pump/res>gpu>rad>cpu>rad>pump
That is fine. No real benefit at all to have rads in between components but it really comes down to how you want it setup.
Loop order doesn't matter. Just wanted to post to say I agree with these guys and we need a stickied guide.
