Posted a new watercooling build in general hardware, but per the advice I got there, swinging over to this forum to ask a few water-cooling specific questions.
My water cooling parts:
Pump: Laing DDCT w/ PetraTech DDCT-01s Top
Radiator: Thermochill 120x3
Res: Don't have yet, might be getting a 5x25 one
CPU Block:NexXos XP3
GPU Block (x 2):EK FC670 GTX Full Copper
The cards I'm planning on getting are 2 x Galaxy GTX 670 GC.
As for the questions:
Sorry there are so many questions, had the whole day at work to think about this.
- Less of a water question, more of a general question I hope someone knows: is Galaxy a good choice of a vendor if I want to OC my 670s? I'm new to nVidia and completely naive to the differences between vendors
- I think my EK blocks come with TIM pads installed - should I be using these, or is it better to replace with another TIM, and if so, what's preferred?
- What's the scoop with nickel plated stuff? Mixing metals seems to be bad news, and it doesn't look like it decreases temperature. Just curious - I've been avoiding it where I can since I don't want the complication.
- Is my little, aging DDC (not sure what version, the PetrasTech receipt from a few years ago just says 'Laing DDCT' going to be able to handle this loop? I've got about 4.5-5 feet of tubing in there now because of the funky way I had to route things. I'm planning on putting my pump down at the bottom of my 5.25" bay tower, rather than underneath it with the radiator, which will make everything much shorter and easier to work with - maybe 3-4 feet then, I hope.
- I just read over the FAQ, which sort of answers this next bit: why all the hype with compression fittings? I stuck 7/16 tubing on 3/8 barbs and never had a drip. FAQ seems to confirm this is OK, so I plan on sticking with it.
- FAQ says reservoir -> pump -> radiator; I've been running reservoir -> radiator -> pump. Is this a huge issue beyond initially filling your loop where you might accidentally run your pump dry?
- Should I be running those GPUs in parallel or serial?
- I want to actually be able to drain my loop this time, easily. Never did that in the old one. Is it as simple as installing a T-line at the bottom of the case, on the way out of the radiator and up to the CPU? Then just slap one of those neat little valve guys or a quick disconnect or something on there and call it a day?
