shivang222
- Dec 31, 2006
Recenctly I just build my computer and it seems like I did okay. It started up, and I went into the BIOS to see my CPU temperatures which were reported to be around 50 degrees celcius, which I understand is too high. However, I was advised to install windows onto my new computer to check the temps through Core Temp. Now, when I boot through a CD the Windows loading files screen comes up fine. Then, though, when there is the screen has Windows on top and a green little bar moving across, the computer freezes and doesn't go ahead.
What could be the problem?
It freezes in a screen that looks somewhat like this:
