- Apr 7, 2000
Specs:
i5-4670
Z87MX-D3H
16 GB DDR3 Corsair Vengeance
120GB Sandisk Ultra SSD SDSSDH-120G-G25
2TB Western Digital Mainstream Classic Wdbh2d0020hnc
Corsair CX750M
After putting everything together, I installed Windows 7 and everything went smooth.
Restarted computer and put in install CD for motherboard drivers.
When loading drivers was finished, restarted computer(as prompted by installer).
Edit:
I also didnt know if I should post there here or somewhere else. So if it is in the wrong spot, just let me know and I will start a new thread.
Computer posts, but wont boot into Windows. Hangs at loading screen then BSOD after about a minute.
After restarting, computer will post, but goes to a screen saying there is no boot drive, to insert media and press any key to continue.
Restarting and entering the BIOS will reward with either the motherboard recognizing the SSD or not, usually not, and if it does its an endless loop of the above.
But, if I dont install the chipset drivers, there is no problem.
No, I dont have the BSOD error because I cant get into windows to make it so it doesnt automatically restart on BSOD.
i5-4670
Z87MX-D3H
Corsair CX750M
Edit:
