I built a HTPC and I cannot seem to keep it stable. The ONLY negative thing is that the 2 HD are used and I had a SATA cable issue (http://www.hardforum.com/showthread.php?t=1275996) that does not appear to be an issue as I am currently formatting one of the HD via a Blu-Ray drive (both SATA) without issue. I must admit that I didn't notice a way to format the disc when I attempted to install Vista and just skipped it. Perhaps that is my issue?
Here's my setup:
Antec Black/silver MicroATX Case w/ 380W PS (NSK2480)
AMD Athlon 64 5400+ 2.8GHz (ADO5400IAA5DO)
GIGABYTE AM2 AMD 690V Micro ATX (GA-MA69GM-S2H)
GIGABYTE EVR Sleeve CPU Cooler (GH-PDU22-SC)
Patriot Extreme Performance 2X1GB 240-Pin DDR800/PC26400 Dual Channel RAM (PDC22G6400ELK) (Does it matter what slot they are in? I believe I put them in the last/farthest two away)
POWERCOLOR HD 3450 256MB 64-bit GDDR2 PCI Express 2.0 (AX3450)
Seagate 500GB SATA 3.0GB 720RPM 16MB Cache HD (ST3500641AS)
Pioneer SATA Blu-Ray DVD-ROM/12X DVD±R DVD Burner (BDC-202BK)
NETGEAR 802.11b/g PCI Wireless Adapter (WG311)
VidaBox Premium Wireless Keyboard with Optical Trackball (ACC-BT-KBOTB)
I've gotten all of my CDs via Bittorent. I am a valid MSDN partner so I have valid keys so the CD's themselves can be suspect. But all of them? Can't find ANYTHING in EventLog!
Here's what I did:
Installed Vista Home Basic (Disc #1)
Crashed during installation of Windows Updates several times
Crashed a few times during boot up
Crashed a few times while copying files, etc..
Realized I couldn't get Home Premium without going through hopes so reinstalled new OS
Installed Vista Ultimate (Disc #1)
Crashed while watching a video on PowerDVD
Just random things.
Same after full Windows Updates
Installed SP1
Same
Installed Vista X64 Ultimate (Disc #2)
Wouldn't install. Random files seem to be missed. Always a different one.
Installed Vista Home Premium (Disc #1)
Appear stable at first
Crashed during Windows Updates
Several BSOD while doing random things. Never a pattern
Installing Windows XP Media Center (Disc #3)
Install says XP Professional. I am hoping it isn't but it's a valid test. I been formating the 500GB HD for the last few hours and doing to see if it installs. If it does, I will probably install Vista on the other HD again to see if I get lucky.
Also, Vista X64 Business has been ROCK solid on my other PC after I replaced the nVidia card with my ATI HD 3850.
Any advice? I am about ready to throw it out in the street.
Here's my setup:
Here's what I did:
Just random things.
Installed SP1
Same
