New Build Problem... No Display
JMesser91
UPDATE: So I borrowed an old pos graphics card from a neighbor and it worked and I got a display on my monitor. Therefore it must be my graphics card. Is there anything I can try to get it to work or is it just a faulty graphics card?
Okay. So I initially built it with everything in the case. I got everything hooked up and then turned it on. All the fans started spinning (including cpu and gpu). The optical drive was active as well as the hard drive. I got power to my keyboard and mouse as well. However, nothing would display on the monitor.
I then tried to rebuild it with everything out of the case as normally instructed to. I set up the motherboard, gpu, 1 stick of ram, cpu with heatsink, and connected the monitor. Again, I got no display.
Just ask if you need to know anything I didn't provide. Any help is very appreciated as this is my first build and it is a little frustrating.
System Specs:
Asus P5Q Pro Turbo
Intel Q9550 Quad Core Processor
Sapphire ATI Radeon HD 4890
G.Skill 2x2gb RAM 1066 x2 (although I never even opened the second set yet)
WD Cavier Black 500GB
WD Cavier Black 1TB (for data sotrage, never hooked to motherboard)
Sony Optical
Antec 900 w/ 650w PSU
Asus 21.5" LCD Monitor
EDIT: Do I plug an 8-pin or 4-pin power connector into the second power cord slot on the motherboard? It's an 8-pin connector on the motherboard, but it originially had 4 of the pins covered by a black piece of plastic (like a gaurd).
EDIT 2: I read somewhere you have to have special PCI-E power cables to plug into the video card. My power supply has one PCI-E power cable that is labeled for PCI-E. It is a 6-pin with a free 2-pin (to make it an 8-pin). Other than that there is just a 4, 6, and 8 pin power cable. I just plugged in the other standard 6-pin power cable to the other power connector on my video card.
If your PSU has the 8Pin CPU power connector, plug it in. If not, the 4Pin will suffice.
Your video card requires TWO 6Pin PCI-E connectors. Did you remove the +2 Pin and plug in that 6Pin PCI-E connector?
Yes. I plugged in the labeled PCI-E power cord into the the gpu as a 6-pin and then plugged the unlabeled 6-pin cord in as well.
I have tried both the 8 and 4 pin power cable to the motherboard. Niether worked.
I have tried 4 sticks of ram in total, in various different slots.
I have reseated everything atleast twice. I have checked the monitor on my laptop and it works.
Everything seems to work. All the lights and fans come on and everything, just no display.
Try your video card in another system.
You seem to have everything plugged in properly. You only need to plug in the 4 pin 12V connector into the 8 pin EPS 12V connector on the Asus P5Q pro motherboard. The other 4 pins that's covered is for additional power for higher powered cpus like the Core 2 Extremes cpus with 150W TDP or when your doing heavy O/C on your cpu. You also have the 2 x 6 pin PCI-E power cable plugged into the HD 4890 1GB. If this is still not working than the best thing to do is try the video card in another system.
