M
mls1995
Guest
Hi all,
Just built a new HTPC today (specs below). At first I couldn't get it to boot. I checked all the connections over and over and eventually it did boot. I was installing Windows 7 on it and walked away. I came back in the room and the system was off.
At this point, it either won't boot at all or if I flip the power supply enough and wait it will power on and shut down. I was in the bios and all components are detected.
Do I have a bad power supply? What should I do to test it? I won this power supply from [H] and Seasonic so I can't return it but I can buy a new one if that's what it takes. I've built multiple successful builds without any issues like this. I've even build in this case before.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: Noctua NH-U9S 46.4 CFM CPU Cooler
Motherboard: Asus MAXIMUS VIII GENE Micro ATX LGA1151 Motherboard
Memory: G.Skill Ripjaws V Series 32GB (4 x 8GB) DDR4-2400 Memory
Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive
Storage: Western Digital Red Pro 6TB 3.5" 7200RPM Internal Hard Drive
Case: Silverstone GD08B (Black) HTPC Case
Power Supply: SeaSonic Snow Silent 750W 80+ Platinum Certified Fully-Modular ATX Power Supply
Optical Drive: LG WH14NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft Windows 10 Home OEM (64-bit)
