Hey All,
I've been having some GPU issues with my current build from 2013. I am considering doing a new build and still working the details out on that but wanted to see if anyone thought I should upgrade what I have instead of just buying new.
Here's the current setup.
MOBO: ASUS P8Z77-V https://www.newegg.com/Product/Product.aspx?Item=N82E16813131820
CPU: i5-3750k https://www.amazon.com/Intel-Core-i5-3570K-Quad-Core-Processor/dp/B007SZ0E1K
GPU: ASUS GTX 660 https://www.newegg.com/Product/Product.aspx?Item=N82E16814121660
RAM: 16GB DD3 2133 https://www.newegg.com/Product/Product.aspx?Item=N82E16820231476
PSU: Rosewill 750W https://www.newegg.com/Product/Product.aspx?Item=N82E16817182073
SDD: Brand new Samsung 250G SSD and a less than 1yr old WD 1TB magnetic for data, no issues here and plan to reuse these either way.
My biggest objective is to upgrade the video card for some moderate gaming and be able to play any newer games coming out on somewhat decent settings. I'm not planning on going VR and no plans on 4k at this point, although I plan to look at display upgrades after this.
The big question is would you even consider doing a GPU upgrade on this mobo/rig to something like even a GTX 1080 or look at starting from scratch. I could go broke and strech my budget to somewhere around 1500-2k but if I could confidently get away with a $300-$500 GPU upgrade for the next couple years I would like to go that route.
Thanks for the time and feedback!
