Got the upgrade bug again... The system will be used primarily for gaming @ 2560x1600 (Dell U3011) with as much eye candy as possible while maintaining 60+ fps. I'm aiming for high performance with a healthy overclock on the cpu, but I want to keep it quiet.
Intel Core i7 2600K - I don't mind the extra cost over the 2500K
-still undecided on the motherboard
2x MSI Twin Frozr II OC 6950 2GB - reportedly very quiet & cool, unfortunately not unlockable, my first time going multi-gpu
Intel 510 Series 120GB - OS drive
Seasonic X750
Sound Blaster X-Fi Titanium HD - optical out to receiver w/ polk monitor30s + sub (thought about going HDMI out from one of the 6950s but I need to upgrade the receiver first)
Corsair Obsidian 800D + 6Gbps sata upgrade - gargantuan, but I like the cable management + look
Thermalright Venomous X - have one in my current system, good performance
Scythe Gentle Typhoon 1450 120mm - cpu fan
Scythe Gentle Typhoon 1150 120mm - case fan
Thermalright X-Silent 140 - case fan
Lamptron FC-5V2 - controller to quiet down any fans that get noisy
Gear Head 24X DVD+R - a little more expensive than some others, but reportedly quiet
+ miscellaneous sleeved cable extensions for power supply/fans
Windows 7 Pro 64
See anything there that stands out as good/bad/ugly/missing?
Gigabyte P67A-UD5-B3
MSI P67A-GD80
ASUS P8P67 Deluxe
Seasonic X750
Windows 7 Pro 64
