quasinewbie
- Dec 3, 2006
Hi,
I'm about to build a new computer and as it's been quite awhile since I've built one I'm looking for opinions on compatibilities and practicalities.
Presently I'm using a 500Mhz P3 computer which I got around 1999. I'm running Windows 98 SE. I haven't built a computer since about 1993 when I built a 486. I've been scanning the forums and studying user and professional reviews for quite awhile and I am still not sure if I'm on the right track. My wish list can be found at https://secure.newegg.com/NewVersion/WishList/MySavedWishDetail.asp?ID=4121407
My present monitor is a Samsung SyncMaster 940T with a maximum resolution of 1280 X 1024, which I intend on keeping.
I keep a computer for awhile. I try to get one that's close to state of the art, so that it will serve my needs for a few years without too much upgrading.
I'm not presently much into gaming, but I won't rule out the possibility later on. I would like to transfer my extensive collection of VCR's onto DVD's. That is one of the reason's I decided to get a new system. I had bought a DVD burner and after I got it home I noticed that the minimum system requirements called for at least an 800Mhz Pentium. Also audio editing can take a little time, even using a ramdisk.
I am considering either the ASUS motherboard that's in my wishlist or the Intel 975XBX2KR Intel Socket 775 ATX motherboard. I don't see any point for OCing, unless I really get into gaming.
Any help is greatly appriciated.Thanks.
