diztrukted
- Mar 1, 2010
I just built my very first PC. I intend to use it primarily for gaming, but for work also (some photoshop, some 3d modelling programs). I saw this thread http://hardforum.com/showpost.php?p=1033078592&postcount=2 and thought, maybe this is the next step, to make sure everything's running properly. I tried 3dMark06 and it finished the test and during one of them, it would run at 2 or 3 FPS (red valley test)...the rest were fine. I used Furmark also, this one went for a long time to the point where I just closed out of it. At one point it did reach somewhere in the high 70's for temp readings but that was about a half hour in before it went back down. I also ran OCCT and at first, within the first 2minutes it would say CPU too hot and making a quacking noise. Ran it again and it seemed fine, but again, i don't what it is I should be doing here or how long it should run.
Typically what do you guys do to tweak/alter your hardware for optimal performance?
How long do I run these tests for?
I don't know what a lot about benchmarks and stress testing cpu's and gpu's, what do i do?
Any help would be much appreciated.
Side Note: should I be overclocking? How do I overclock? What about hyperthreading? Should I even concern myself with any of these?
WHAT I'M WORKING WITH
\\ THERMALTAKE ELEMENT T | CORSAIR CMPSU-850TX | ASUS P6X58D
\\ INTEL CORE i7 930 2.8 GHz | CPU HEATSINK COOLER MASTER RR-UV8-XBU1-GP
\\ RAM CORSAIR DOMINATOR 6GB (3 x 2GB) | SAPPHIRE RADEON HD 5850
\\ SAMSUNG SH-S223F| WD CAVIAR INTERNAL l HDD |SAMSUNG SPINPOINT F3 HD103SJ 1TB | INTEL X25-M MAINSTREAM SSD
\\ WINDOWS 7 PRO 64-BIT | ASUS VW246H | RAZER MAMBA MOUSE
