I connected together the CPU, Motherboard, GPU, RAM and Video card and get no output on the monitor.
Hardware:
Motherboard: EVGA 680i SLI
CPU: Intel Q6600
GPU: BFG 8800GTX OC2
PSU: Corsair HX 620w
RAM: 4gb OCZ Reaper PC2-6400 (2x2gb)
I'm leaning towards the problem being the video card, but here's what happens when it boots.
All the fans come on, including the one on the graphics card.
Goes thorough all boot codes on the LEDs to 25 Shadow VBIOS - Shadow System/video BIOS" where it beeps for several seconds (although the number keeps going up, so not a fatal error). Note: it may start beeping at 26 - "Clock: Gen Init onboard clock generator and sensor"... it changes so fast i cant really tell.
After a few seconds it pauses at 7F POST Error Check - Check POST error and display them and ask for user intervention
However there is still nothing being displayed on screen.
I tried moving the video card to the 2nd PCI-E 16x slot, same problem.
The computer is still responding. The 7F error is waiting for user input. If I connect a keyboard and press F1 it will go to FF, so it's a display issue, right?
I have no compatible hardware to test with but I tried both sticks of RAM on their own and in different slots. I tried 2 different screens which both work on other PCs and both DVI outputs on the video card.
I have no other PCI-E cards or motherboards I can try testing on
Am I right in thinking the video card is dead?
Hardware:
CPU: Intel Q6600
