Intel Q6600 G0 - $214.78
Microcenter
Tuniq Tower 120 - $49.99
http://www.svc.com/tuniq.html
GIGABYTE GA-P35-DS3P Core 2 Quad/ Intel P35/ DDR2-1066/ IEEE1394a/ A&GbE/ ATX Motherboard - $160.48
http://www.clubit.com/product_detail.cfm?itemno=A4830709
Patriot Extreme Performance 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220227&Tpk=PDC24G6400ELK
EVGA 512-P3-N841-AR GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - $296.32
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130325
Antec Performance One P180 Silver cold rolled steel ATX Mid Tower Computer Case - $148.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129154 OR
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=140118&prodlist=celebros
- $105.99
Corsair VX 550W ATX Power Supply - CMPSU-550VX - $84.99
http://www.buy.com/prod/corsair-vx-550w-atx-power-supply/q/loc/101/205852646.html
SAMSUNG 20X DVD±R DVD Burner with LightScribe Black SATA Model SH-S203N - OEM - $31.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151154
Western Digital Caviar 320GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive - $72.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136098
TOTAL: $1160.51
im wanting to know if this is a good build or do i need to change anything? thanks
Microcenter
- $105.99
TOTAL: $1160.51
