Hello,
Im working on a parts list for my new build, and i need some advice for the water cooling portion. Thank you
Heres the info what i have and intend to buy.
Items i have
Case: Danger Den Double Wide 21 nightmare edition with star wars fan grills
Power supply: Corsair AX1200
Pump: Swiftech mcp655
Items i intend to buy
Motherboard: ASUS Rampage IV Black Edition with EK full chipset water block
CPU: I7 4930K with EK water block
Ram: Either 16GB of Corsair Dominator Platinum or GSkill Trident X ( not sure on the best speed i need yet.)
Graphics cards: 3 GTX 780 ti with EK water blocks and back plates
Pump: EK pump top with 140m res
Radiators: 3 aerocool NexXxus Monsta 360 with 6 1500 Rpm fans in push/pull on each rad, 1 aerocool 80mm rad with 2 2200 Rpm fans in push/pull
Tubing & fittings: promochill rigid acrylic tubing 1/2OD-3/8IN and fittings.
What is the best loop order and will these rads work for my cooling needs? I plan to overclock the system as well.
Heres the loop order i was thinking on doing
pump>north bridge>cpu>south bridge>80mm rad>graphics cards>360 rad>360 rad>360 rad> res
Items i have
