Amplify4575
- May 23, 2005
-Lian Li PC-65B Black Aluminum ATX Mid Tower Computer Case - $122 - (mmm)
-DFI LANPARTY UT nF4 Ultra-D - $135 -(I've seen how popular this board is here)
-AMD Athlon 64 3200+ Venice - $193
-JATON Video-PX6600 Geforce 6600 128MB PCI-E x16 - $112 - (not planning on playing games much)
-Rosewill RP500 ATX 500W PSU - $54 - (good 12v rail and has 24pin connector needed for mobo)
-TwinMOS 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered System Memory Model TMII400/1GB - $87 (need help here, I would like to oc with at least 1gb of RAM)
-2 x WDigital Caviar SE WD2500JD 250GB 7200 RPM SATA HDD - $249
-NEC Black IDE DVD Burner Model ND-3520A BK - $46
Ok. I do plan on oc'ing this comp. I would like a good stable oc, but also be able to take it as high as it can go stably for fun. Shortly after purchasing this setup, I plan on watercooling it (AC parts), so maybe that can help out with the temps and stability. Oh and for you gaming freaks, don't rag on the vid card selection
I just want to be able to enjoy a good game here and there. Maybe later on when everything is set up and I get more money I'll get a better card. Please add some suggestions to better parts for the value/performance. I appreciate it. Thanks, guys.
