GJSNeptune
- Mar 31, 2004
Assembled my parents' new computer yesterday evening.
Cooler Master Centurion 541
GIGABYTE GA-MA69GM-S2H AM2 AMD 690G HDMI mATX (Radeon Xpress 1250)
AMD Athlon 64 X2 4800+ with stock HSF
2X1GB mushkin DDR2-800
Seagate Barracuda 320GB 7200.10
Corsair VX450 450W
1) The first concern I had was with the stock HSF. It produces a subtle rattling noise. If I poke the fan with my finger to slow down the fan, the rattling gets a little softer, and if I stop the fan completely, the rattling stops. I also noticed a rattling reduction when I touch the heatsink, especially on opposite sides. It's not a clicking sound like a failing fan. It's more like on Wheel of Fortune when they spin the wheel, only not as harsh or loud. Maybe more like a fast, quiet ticking. Anyone ever experience this with the stock Athlon 64 X2 HSF? I replaced the stock thermal grease with AS5 and BIOS shows the CPU temp at 36-37 C. Seems pretty good, right?
2) The Seagate is LOUD! Granted, I've only had the case up on the desk (it's a surprise present for my dad's upcoming birthday) with the vented side facing me. It clicks and grinds really loudly, but doesn't quite sound like it's failing. It's also secured by those plastic rails. But I have three WD drives in my computer secured by just screws and they're no where near as loud. I hate going through the RMA process, but it's unbearable. My parents have a hanging tower mount under their desk, so I'll try to get it under there and see how loud it is then. Hopefully it's healthy, but just loud.
3) This case comes with a front audio cable that can do either HD Audio or AC'97. The case instructions aren't written clearly, and I was under the impression that it called for using the AC'97 support. I tried it but the headphone jack didn't produce any sound. I haven't tried the HD Audio connector yet, and will after work today, so hopefully that'll take care of it.
4) The Vista rating is 1.0 due to the integrated graphics. All the other categories were above 5.0. I researched and was told that Xpress 1250 could run Aero smoothly. While I've only had it running a few times to install antivirus and an mp3 to test audio (it was getting late), I didn't think Aero showed any lag. On the other hand, one of the times I booted into Vista and plugged in a thumb drive, it seemed Vista froze. The mouse cursor would change hover effects, but nothing could be clicked. And about thirty seconds later all the changes suddenly happened. Not sure what that was about. Hopefully it was a one-time thing.
Corsair VX450 450W
