new build/memory id
omz
hey guys, anyone know the chips on this memory?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145033
i'm building a computer for my friend and another friend of mine hooked him up with some memory;)
i'm mainly concerend because...well i just want to know:D
btw, since i'm on this topic, how's this build so far?:)
CPU: E6700 (free from a friend)
Mobo: Gigabyte DS3
VCard: eVGA 7900GS
Memory: TWIN2X2048-8500C5 (same as above)
along with some other nice goodies.
thanks for the input guys:D
Depends on the revision, Micron of Infineon: http://ramlist.ath.cx/ddr2/ ... you really don't need that high speed ram with an E6700, unless you want to lower the multiplier from 10 down to 7 or 8, hehe.
I'd go with an X1950Pro over the 7900GS... better performance for not much extra money. What resolution will he be gaming at?
BTW, I'd like to be a friend of your friend who hooked up your other friend with that CPU and RAM for free :D
oh man, it's been a really long time since i've looked into comps. can you explain or link me to multis and ddr2 speeds? thanks
and btw, he got the 7900gs free from the same friend ;) but for the res, he plays at a crappy 6x8 right now (cs 1.6 is all he can play on his comp with about 60 fps) but he wants to play future games. i highly doubt he'll go widescreen so comparing a 7900gs perforamnce to my gtx, it should be able to hold future games at the res he plays.
The stock multiplier of the E6700 is 10, and the base FSB is 266Mhz. The effective FSB is QDR, so its 4x the base FSB. Since your running ram in dual channel, its 2x the base FSB. So at stock settings:
10 * 266 = 2.66Ghz CPU Clock speed
4 * 266 = 1066Mhz Effective FSB
2 * 266 = DDR2-533 DRAM Speed
Overclocking to 533Mhz would theoretically get you:
10 * 533 = 5.33Ghz CPU Clock speed
4 * 533 = 2133Mhz Effective FSB
2 * 533 = DDR2-1066 DRAM Speed
There isn't a board available that can reach that high of an FSB. I think the closest is 525 by the P5B Dlx. And even if you use that board, the CPU couldn't reach that high on air, so you'd have to lower the multiplier. You could raise the DRAM multiplier, but Intel platforms run best at 1:1 ratios.
So with the parts you already have/chosen, a base FSB setting of 450Mhz and dropping the CPU multiplier will get you:
8 * 450 = 3.6Ghz CPU Clock speed
4 * 450 = 1800Mhz Effective FSB
2 * 450 = DDR2-900 DRAM Speed
Since the DS3 can reach 500, I think your limiting factor would be the CPU. So tweak it to find the best combination of base FSB and CPU multiplier. You could even lower the timings on the ram, since you'll be underclocking it, hehe.
If I messed up anywhere, someone will correct me, lol. Oh, do you have a Tuniq Tower in that list of parts that didnt make it to post? Or some other good HSF, like the Scythe Ninja/Infinity, Zalman 9x00, Ultra 120, etc?
aha! makes sense now:D
i'll ask my friend if he has some ddr2-800 ram instead of 1066, i'm sure he has some lying around...
as for the cpu cooler, i haven't looked into which specific one yet, but i was leaning towards teh zalman (heard some great stuff about it). i personally don't like the scythe/tuniq because they're HUGE and may have some issues with the case
Well if you already have the DDR2-1066, then don't worry about it... just keep 'em.
The Zalman isn't small, either, lol... its big, just like the scythe towers and tuniq. They're all pretty good. What case were planning you using?
well, looks like the apperance of the hsf won't make a difference as he decided to go with a non-window case. i believe he is going with the antec sonata 2, it seems like it should fit.
as for the, i guess i spoke to soon. my friend can't get the 1066 but he was able to get some ddr2-800 ram. link is like so:
http://www.newegg.com/Product/Product.asp?Item=N82E16820145590
can't really tell what the IC is unless i know the rev number, so i guess i'll just have to wait.
now that he's ordered the case, how would the psu for the other parts be? the psu that comes with the sonata is a smartpower 430 watt i think. any info on that?
thanks again guys:D
There are still some bad 450W PSUs out there, from Antec's bad batch. Test it first, and make sure it doesnt need RMA'ing. If all the parts of his system were the ones you listed, then it should be fine, if its a good unit. Though, imo, I'd replace it, and keep it as a spare instead. I'd replace it with either a goodpower 500W, stablepower 460W, enhance 5150GH or corsair 520W.
