Spacy9
Scotch is my Lord and Savior
- Oct 13, 2000
My new build keeps going to BSOD - did it during the build and is still doing it. Has corrupted windows several times now. The BSOD doesn't give me an error, instead it gives me a STOP message which I can't find anywhere and it is exactly the same each time:
*** STOP: 0X0000008E (0x0000005, 0x408821E6, 0xF78D23C4, 0x00000000)
Any ideas as to what this is or what it means?
The parts are:
ASUS P5N32-SLI SE Deluxe
Core 2 6700
Thermaltake Toughpower 750W
4 1 gig sticks of G-Skill 800Mhz memory
XFX 7950gx2 (have 2, tried swapping them with no luck, same issue. Only planned on using one till everthing was set up and then install the other.)
2x250GB HD in RAID 0
2x400GB HD in RAID 0
Thanks for any help, I'm getting desperate!
The parts are:
Core 2 6700
