dissonance
- May 16, 2005
First of all, here's the system:
AMD 64 3200+ Venice
Epox 9NDA3J
Leadtek 6800nu (was unlocked on old system, haven't unlocked on this one yet)
1x1gb Patriot 2-3-2 RAM (soon to be 2x1gb)
Maxtor 200gb SATA hard drive with 16mb cache
Lite-On DVDRW
CoolerMaster Centurion 5 case
Enermax Noisetaker 420watt
1) I have trouble powering this on sometimes. I'll hit the power button and I'll get a short burst of fan movement and then nothing. Pushing the on button again does nothing. Typically I have to turn the psu off and wait. Then if I'm lucky it starts. Once it starts I have no problems and restarts appear to work fine. What could be causing this? I keep my computer on nearly 24/7 but this is just annoying. When I had XP turn my system off the psu fan continued to spin which is supposedly normal for this psu however my mb diagnostic lights also stayed lit and the psu fans didn't go off after several minutes.
2) Windows XP has recognized my 200gb SATA drive as 127gb. I saw this while installing the operating system but thought it would work out. It still shows the hd as 127 gb. Again, annoying.
So here's how I went about installing it. The mb is a 20-pin with a 4 pin next to it. So my psu came with a 24 pin so I took the extra 4 off and plugged in the 20. The extra 4 off the 24 is not being used. Then I took a 4 pin 12v rail which looked about identical to that 4 pin off the 24 and put that in the 4 pin slot on the mb. That's how the instructions on the psu seemed to direct me.
When installing Windows XP I didn't F6 or anything. In my bios it recognizes the SATA drive and properly identifies it as 200gb. Windows XP install recognizes the drive but sees it as 127gb. Also after I got into Windows it has one of those "Safely Remove Hardware" icons in my system tray. I click it and it lists my hard drive... Perhaps I was supposed to install some SATA drivers either with F6 while putting on Windows or afterwards? I found this file but it doesn't list my mb.
http://www.epox.com/usa/article.asp?ID=1752&showsupportlinks=YES
I have the dvdrw in the IDE 0 first spot. HD is in SATA first spot. Boot priority is hd, dvd, floppy.
Anyone have any ideas? Thanks for any help.
AMD 64 3200+ Venice
Epox 9NDA3J
Lite-On DVDRW
