New Build Issues - P8Z68-V CPU Light
murlo26
So I took suggestions from my other thread on this forum on what to buy and all of my components came in last night. I took my time putting everything in and got it all put together and it fired up right away to bios, yay right?! (By the way, I never installed a Hyper 212 cooler before, it kind of sucked, but is easy once you figure it out).
Anyway here are the build specs:
ASUS P8Z68-V Mobo
Intel 2500k CPU
XFX HD 6950
Coolermaster Hyper 212 Cooler
G. Skill DDR3 1866 Memory Sniper Series (2x4GB)
OCZ Vertex 3 SataIII SSD 120GB
Corsair 750w TX Power Supply
WIN 7 x64 Pro
So here is what happened so far.
I fired it up, it booted great, no MOBO post lights. Got into the BIOS, selected my boot priorities and just snooped around not changing anything and saved settings and exited the bios hoping it would boot up my Win 7 Intstall disc, which works as I tested it with my same disc drive on my old rig before I disassembled that as I reused my case, ps and disc drive.
It didn't boot to the disc at all. I waited a long time, still nothing. I reset it a bunch and it would just get to a black screen with white underscore in the top left siting there forever. So I looked in the manual and my memory wasn't one of the explicit supported ones so I used the MEMtest button on the board and that worked great. Also, just for reference in the bios it recognized all my memory at the speed it said it would (1600) and had the right CPU in there and everything.
So now I figured i would try again...nothing. Pulled a stick of memory same thing. put all the memory back in and came to read up on the board. Many people complained of failed DIM slots which I don't think I have but several said flashing the newest bios on fixed there problems. Went to the ASUS website, got the newest bios rev, put it on a USB drive and flashed it using the flash utility in the bios. It said success and rebooted.
Now the damn thing won't even post into bios. It has the Red CPU light already lit. I am guessing either the mobo and/or CPU is bad...leaning toward mobo.
I tried to clear the CMOS, nothing, pull the battery on board and clear CMOS, still nothing. One stick of memory nothing.
My next move is I am going to pull my cooler and inspect CPU pins to double check but I really doubt its that as it worked fine before I flashed the BIOS.
Any ideas?
I did see one guy on newegg flashed the newest bios and the same thing happened. He RMA'd the board and all was well. Should I start and RMA?
Thanks for the help guys!
Well Pre-Flash I would have suggested you re-tweak your boot priorities, and look into your CD drive to make sure that is working. Just because it WAS working on your old rig doesn't mean it will also work on the new. Try plugging it into another SATA port, and also try creating an install flash drive with windows 7 so that it boots off of a USB stick. It could very well be trying to boot off of something other than your windows 7 CD.
Since you could go and manipulate the BIOS, I would have doubted that it was a MoBo issue. However, if you can no longer even access BIOS after flashing, then you have a problem. I would try reseating the CPU/all the ram, make sure CPU is lined up properly (with the small arrow on the corner), etc. Otherwise, you might have to RMA.
I tried several times to change the boot priorities and reboot. Did it in the easy bios deal and the advanced, nothing seemed to work. It recognized the drive right away so it could see it. The win7 dvd was tested literally and hour or so before I used it on the new rig as I made it on my old rig, took the computer apart installed new stuff and then that is where I was. I suppose trying the USB or a different SATA port would've been a good idea but its too late now I think.
The CPU is lined up correctly, I triple checked before putting it in. But I am going to try pulling it off and reseating it when I get home.
Anyone else?
Well I heard back from ASUS last night they said just RMA the board to my vendor after reading what I wrote.
So Newegg is doing an advanced RMA to me today and I should have a new board tomorrow. Hopefully that fixes the problem.
Just an Update if anyone else ever sees this issue.
I got the new board through advance RMA from newegg (i love newegg btw) last Friday. Put the new board in Saturday morning and BAM everything works perfectly now. Still need to work on my overclock, just using the ASUS software in windows for an OC when I need it which gets up to 4.3ghz with autotune. I am hoping for 4.5-4.8 region but that is for another discussion :)
Bottom line is I believe the board was bad from the beginning it looks like.
Good to hear it's all up and running now!
Yea it feels great to not have to dink around with it more. I hate RMA'ing stuff, so much work to coordinate.
SSD is by far the best investment, boot up times are non-existent now.
