Greetings everyone. Did a new build over the weekend and have a problem and I'm looking for some help.
Summary: On the very first power up, hit power button, everything started to spin up and it stayed on for all of about 5 seconds, if that. It simply turned off. I heard no beeps or noises that I can recall.
After this, I see no red led standby light on the mobo. Nothing to indicate there is any life at all.
Here are the relevant specs--all parts new except memory:
Mobo: Abit NF7-S v2
AMD 2600 XP-Mobile
Memory: 2 x 256 mb chips, Ultra PC3200 DDR400 (pulled from same type mobo in an older machine)
PSU: Enermax Noisetaker 370w
XFX 6600 GT AGP
Seagate 120 gb hard drive
Thermaltake Volcano 12 heatsink and fan
Here's what I've done:
1. Panicked.
2. Unplugged PSU.
3. Reset CMOS clear jumper to clear and removed battery.
4. Unplugged all peripherals, video card memory, etc.
5. Unplugged and carefully checked every power connection in the box.
6. Flipped PSU power switch a few times, per instruction manual, which talks about the auto PSU self-protect and reset mode.
So, basically, I have a dead box giving me no signs of life. Since there is no light from the red standby led on the mobo, I am thinking there is a complete absence of power and I may have a dead PSU as opposed to a dead mobo. On the Abit tech support forums, even the mobos that turned out to be dead still showed when they were receiving power with the red led turned on. So, that is why I'm leaning to suspect the PSU.
I intend to check this by pulling everything out and attaching a different PSU with minimal components.
Does this sound like the best course of action here? Has anyone experienced something similar? Thanks in advance for any help and suggestions!
Lawdog
Mobo: Abit NF7-S v2
AMD 2600 XP-Mobile
XFX 6600 GT AGP
1. Panicked.
2. Unplugged PSU.
Lawdog
