new build inside please review.
JDM-Y0-
Okay flame away or help me out on some good ram. I need atleast 2GB
What I already have.
AMD Athlon 64 X2 5200+ Windsor 2.6GHz 2 x 1MB L2 Cache Socket AM2 Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103759
XFX PVT80GGHF9 GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150171
EVGA 122-M2-NF59-TR Socket AM2 NVIDIA nForce 590 SLI MCP ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188016
Scythe SCNJ-1100P 120mm Sleeve CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185038
COOLER MASTER Centurion 5 CAC-T05-WW Black/Silver Aluminum Bezel, SECC Chassis ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119077
Antec True Power Trio TP3-550 ATX12V 550W Power Supply with Three 12V Rails 100 - 240 V UL, CUL, FCC, TÜV, CE, C-tick, CCC, CB - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371002
What I NEED
What I need is atleast 2GB of some good ram. I'v been reading how alot of boards dont like alot of ram. What do you think I should go with? I have around 250 to spend. Also is the new build going to allow me to run dx9 on COD2? That is the only game I play online.
Foxconn... My wife has a foxconn that is Identicle to your board...\
OCZ 667 Gold works fine, and Kingston VR 800Mhz worked fine and even O/C some.
The layout of the board is a little tricky FYI. Any large coolers will overlap the memory area... blue orb.
I havent checked lately, but OCZ Gold had issues with AM2... but those issues may have been resolved by now.
If OCZ did have any issues then it must have been resolved... I have the Gold 667 upto 2.4 at 900Mhz from there 667 and had not one issue... that was with my Fatal1y board in the side and they work in hers without issues... i have DDR2 800 Plat in mine now and no issues...
Hey that looks a lot like my rig...I've been craving an 8800GTS but I'm going to hold off until summer for the refresh parts.
I've got the eVGA board and it's been running fine for me with Corsair ram.
OCZ man... go for the limited edition special ops ram tight timing. very fast pc6400
