Cook_1
- Aug 2, 2004
I want to build a PC for FFXIV Shadowbringers. I've been totally out of the loop hardware wise for sometime now so could use some help. My laptop has been doing just fine but I think I need something with a bit more bang.
Max budget is $1500 and just the tower built, have everything else. If I can stay under this that would be great, this is just the max I'm willing to spend.
Monitor: Dell U3415W (QHD 3440 x 1440 at 60 Hz)
Type: I want to do a mATX build to save on space and I'm not looking to OC.
CPU: I don't know which would be better here, I've been in the Intel family for a long time but once upon a time I was an AMD fan as they offered the best bang for the buck.
GPU: I know FFXIV favors Nvidia, what range of cards should I be looking at here?
HD: The last hard drive I bought was a 3.5" SSD - it seems things have evolved a bit since then. Any info on what to look for here would be great.
Motherboard: Any specific features I should be looking at?
RAM: I know I want 32GB, I'll find the best set available in my price range.
Case/PSU: These I can figure out on my own.
