MasterOfPupets
- Jun 22, 2004
Gaming.
About 1200 total including tax/shipping.
Cleveland, Ohio so I have access to a local Microcenter and Best buy, not much else.
CPU, RAM, Case, Mobo, Vid, HDD, SSD, Monitor
Reusing Power Supply (OCZ 600w ModXStream Pro), Speakers, KB/Mouse, and ODD.
6) Will you be overclocking?
Some, nothing too extreme
Plan on getting a 1920x1080 monitor.
About a week to start ordering
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Prefer USB 3.0 and SATA 6Gb/s
No, included in spending. WIN7 64-bit
Current Plan:
CPU: i5 3570k - MicroCenter 189.99 Here
Cooler: CM Hyper 212 EVO - NewEgg 29.99 Here
MOBO: GA-Z77X-UD3H - MicroCenter 114.99 Here
Video Card: XFX HD 7850 - NewEgg 254.99 Here
RAM: Corsair XMS3 16GB (4x4) DDR3 1600 - NewEgg 94.99 Here
Mon: 24" 1920x1080 monitor - local 150ish
HDD: WD Caviar Green 1TB - NewEgg 95.99 Here (May possibly up it to a 2TB since the price difference isn't much if I can afford it.)
SSD: Used off [H] I've been seeing some good prices for an OS drive.
Case: COOLER MASTER HAF 922 RC-922M-KKN1-GP - NewEgg 79.99 Here
WIN: WIN7 Home 64bit - NewEgg $99
I'm unsure about the case. I read in the reviews about issues with the ATX power cable being too short. Any suggestions for a different case with better airflow still in my price range?
Any other suggestions on what to change up on the build?
Gaming.
Current Plan:
