New Build-Help With Memory\other Suggestions
I am building the rig for a family member so there will not be any over clocking and trying to keep the budget around 1500 to 1700. I just wanted to build something fast and very stable. I am not familiar with DDR2 and core 2 duo so I am needing some help picking memory (4200/5300/6400)and would appreciate any other suggestions. Here is the list of parts so far:
Intel Core 2 Duo 6600 $312.00
Asus P5B Deluxe $182.99
Evga 8800GTS $489.00
Seagate Barracuda 250 GB $74.99
Seasonic S12-430 $94.99
Antec Solo/Black (will the
8800 gts fit?) $89.99
NEC DVD Burner $30.99
Windows XP $89.99
Memory that I have looked at
Crucial DDR2 5300 Anniversary $229.99
http://www.newegg.com/Product/Product.asp?item=N82E16820148017
Corsair XMS2 DDR2 6400 $239.99 a/r
http://www.newegg.com/Product/Product.asp?Item=N82E16820145590
And I am open to any other suggestions. Just want the best price to performance on these with out o/c. Will there be any performance difference between the slower memory and the 6400 without o/c.
If there is anything else you would recommend as far as the rest of the system please post. Thanks for the help in advance and sorry for the stupid questions.
Thanks
Fish
Edited: 11/11/2006 at 04:23 PM by plasticfish
No, stick with DDR2-533 or DDR2-667. For the best performance without OC'ing, get the kit with the lowest latency. For the best compatibility, make sure its 1.8v (not 1.8-2.0, 1.9, etc). For the best value, get the cheapest 2gb kit (you won't notice much with lower latency ram, esp if you're not oc'ing). The higher latency of ddr2 is compensated by the higher speed.
2gb egghunt: http://www.newegg.com/Product/Produ...deValue=524:10501&PropertyCodeValue=524:16064
Oh, and if you decide on ocz, don't get the gold sticks. Also, if DDR2-800 is only $10 more, you could get it in case they want to oc later on.
EDIT:
I'd go with these sticks:
$200 - CORSAIR ValueSelect 2GB (2x1GB) DDR2-667 VS2GBKIT667D2
CPU Ratio // Memory Speed // Best Memory Timings // Voltage
4:3 // DDR2-400 // 3-2-2-5 // 1.9V ..... 1:1 // DDR2-533 // 3-2-2-7 // 2.1V
4:5 // DDR2-667 // 3-3-3-8 // 2.1V ..... 2:3 // DDR2-800 // 4-3-3-8 // 2.2V
