Hey, I'm currently planning to build a new system and I need some suggestions. I have everything planned out already, but I'm not sure if I could do better with the money. This is going to be a build for college so it'll have to last me for a while. Here's the parts list, just give me a few suggestions please!
Case: Aspire X-QPack: I want this mainly for the size. I go to
LANs decently often and I don't partcularly like the Socket 939 shuttles. This is small enough to fit on an airplane as carry on and large enough to accomodate my needs. I have an Audigy 2 ZS that I want to use and the shuttle cases don't have an extra PCI Slot and they're pretty expensive, so this seems to be the best deal I can find for now.
Mobo: JetWay A210GDMS-Pro: The aspire case only takes Micro ATX mobos and this seems to be the best one currently available. I'd like to have one based off of an Nforce 4 chipset, but the only one available has very few overclocking options, and this is the only one that has options for voltages, HTT, and ram dividers.
CPU: 3700+ San Diego Core: This is the lowest rated san diego core and I've heard it has good overclocking potential. The board should be able to handle it and I'm planning to overclock to around 2.7 ghz (250mhz FSB)
RAM: 1GB Geil DDR 500: I've heard decent things about this ram. It has timings of 2.5 and runs stable at 250mhz.
HD: 2x 120GB Seagate Barracuda 7200.7: Again, I've heard good things about these hard drives. I'd like to get a couple of raptors but those are simply out of my price range. These on Raid 0 should provide enough speed.
Graphics Card: 7800GT: This technically isn't out yet, but it should be coming out around August 11th for 400 bucks. It's the latest generation and supports Pixel Shader 3.0 which should last me a while. Unless I can get a good deal on a GTX, I think I'll be going for this one.
Power Supply: I heard the Aspire X-QPacks are shipping with beefier power supplies now that have 30amps on the 12v rail. This should be enough, and the Jetway mobo takes a 20pin connector so I think it should be perfect.
Now, the case has decent ventilation but I'm also going to be putting in two 120mm slot coolers and I think that'll help ventilation a lot when I'm overclocking.
My one really big concern is with the heatsink. I just purchased a 3700+ OEM from Monarch ($260) and now I need a heatsink. What heatsinks are compatible with this mobo/case combo? I heard the max height is around 80mm and that rules out A LOT of heatsinks, including the Thermalright XP-90 that I was eyeing for a while now. Anyway, one that I found that would fit is the Artic Cooling Silent 64 hs/fan, the only problem is I'd like to overclock to around 2.7ghz (250mhz fsb) and I'm not sure if that'll be enough cooling. If you guys have any suggestions it'd be great, thanks a lot!
