dannitohoot
- Apr 6, 2008
I'm helpin my bro put together a new comp. Here's what he's lookin at...
ASUS M3N78-EMH HDMI AM2+/AM2 NVIDIA GeForce 8200 HDMI Micro ATX AMD Motherboard
AMD Athlon 64 X2 6400+ Windsor 3.2GHz Socket AM2 125W Dual-Core Processor Model ADX6400CZBOX
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL6D-4GBMQ
Seagate Barracuda 7200.10 ST3160815A 160GB 7200 RPM IDE Ultra ATA100 Hard Drive - OEM
SAMSUNG 20X DVD±R DVD Burner with LightScribe Black PATA Model SH-S202N - OEM
Cooler Master 10-Bay ATX Computer Case w/550-watt Power Supply & 9.84-inch Blue LED Fan
http://www.geeks.com/details.asp?invtid=939PL&cat=CAS&cpc=CASbsc
He's adding two 90mm fans as well.
The mobo has an onboard GPU. I told him that the power wouldn't be excellent, but he's okay with that. He says he can upgrade the video card later. The main purpose is to be able to run Vista 64 and DirectX10. This will probably be used to watch movies more than anything else. Gaming is a secondary use. Also, he's using his tax rebate to buy this, so price is the main concern. He's tryin to stay below 600... closer to 500. I told him that Intel has better dual-core's. If you can find one that's close to the power and price, that'd be helpful. He's payin 159 for the CPU.
Any other questions, just ask, I'll try to keep up on this as much as possible.
