Thanks for looking in advance, i know how many of these types of posts you all see daily.. I'm about to pull the trigger on a new build and for the first time ever i'm converting over to Intel. I currently have a amd phenom 940BE w/ 4870 1gb.
So this is what I'm thinking to get at this time but i need your suggestion on mobo and psu.
Main purpose: Gaming
Monitor: Sammy T260 25.5"
i7 920 (my good friend bought for me today from micro-center
) good savings. $229.00
G.Card: I'm strongly considering a 5870 (or should I get a 5850? is it worth the extra 100.00) any brand ok or should i get specific like an Asus... ( I think warranty and service maybe what i should consider)
G.SKILL 6GB (3 x 2GB) $149.99 (not sure if I can do better, for the price and timing) suggestions is welcome.
Mobo: *I will tell you that I'm totally lost which direction to go. All i know is that it's going to be a 1366 mobo, I DO WANT to maximize OC'ng. I hear great things about Asus and eVGA. price wise i dont want to spend over 280.00 if i dont have to.. Thoughts so far: EVGA E758-A1 :: ASUS P6T Deluxe V2 :: EVGA 141-BL-E757-TR :: ASUS P6T SE Maybe the most I may consider going up to is a ASUS P6X58D
HDD: Spinpoint F3 HD502HJ x2 or WD black 640(I should get two correct?)
PSU: i am going to need help with this one, i know this is area i shouldn't be cheap on, down the road i know i have to keep in mind the possibility of CF'ng.
HSU: Megahalems (going to try to get the 920 to 4.0)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
OC'ng, raid, CF'ng(maybe later on) single GPU is ok for now.
10) Do you already have a legit and reusable/transferable OS key/license?
yes. Windows 7
Thanks for your feeback
yes. Windows 7
