New Build/HD4850 Crossfire + i7
DarkVater
Hello!
I am currently planning to jump to i7 cpu and CrossFire as cheap as possible. This is steb by steb upgrade, I want the best eye candy available on 1680x1050 resolution. Also I want my PC to fold proteins(quite fast) while I'm at work.
I've been searching internet for component articles, and finally made my way to your forums. At first i wanted to go 260GTX SLI but after reading your article i became more interested in HD 4850 in CrossFire. I don't want to buy monitor bigger than 22" which I currently own (V7 cheapo).
My current PC:
p5k on 1006 BIOS
e6600@3.33 GHZ
Corsair PC6400(4-4-4-10@739 mhz [if remembered correctly])
XFX 8800 GTX
Greenpower 600W PSU
HD SATA MAXTOR 7200 rpm
X-Clio ACase with front and side fan
First or Second Step:
Gigabyte GA-EX58-UD5 iX58 i7 Socket 1366 8 channel audio ATX Motherboard
(one of the cheapest, nice looking, no problems with cable& hardware management)
Good PSU
(I want enough power to run my hardware in Crossfire and formidable OC)
Second or Third Step:
DDR3 RAM x3(that needs to be OCable & fairly cheap )
Third or Fourth Step:
i7 920
First Step or Fourth Step:
2x HD4850 CrossFire
(cheap solution, enough for 1680x1050, cons: ATI's drivers are not updated as often as Nvidia's)
Any advice/comments are much appreciated. Thanks in advance.
Sorry for grammar errors. English is my second language.
So you are from Germany? I would suggest you to get two 1GB HD 4850s, not the 512MB version because when using crossfire, 512MB on each card is not enough.
If you have the money, you should also look into the 2GB HD 4850 X2 or 2GB HD 4870 X2, they shouldn't cost much more than two GTX 260 in SLi in Germany.
Nope :). I'm not from Germany. I have family in Munich, but i've seen them about 12 years ago or something. I'm defo not family guy ;).
My nick derives from Darth Vader, i've read that Vader is Father in Norwegian or Swedish (can't remember which one)...anyways
PowerColor HD4850 1GB - £144.95x2 = £289.90
Saphire HD4850x2 2GB - £295.85
PowerColor HD4870x2 - £346.11 (i wont see GPU advantages on my monitor & also i want my GPU setup capped at £300)
What setup is faster? 4850x2 or 4850 1GB x2 in Crossfire? I reckon it's more fun to have 2cards in CrossFire :D
A bit more advice regarding cheap and reliable PSU & DDR3 Triple Kit (OC able).
If you look at HD 4870 1GB Crossfire vs HD 4870 X2, the X2 is faster.
I think you could get away just fine with one HD 4870...
I think you are right. Because if I change monitor later in 2009 (i doubt it but who knows) i can sell 4870 and get 4870X2 or buy another single 4870 for CrossFire without selling old one.
Ok GPU's sorted.
Now i need to know what kind of OC i need on i7 920 to run HD4870/ HD4870X2 or HD4870 CrossFire in it's full potential and what memories i need to handle that OC.
Also a good advice for decent PSU for that kind of build. (with PSU money saver option=off)
Thanks.
