PolygonGTC
- Jan 6, 2006
I just upgraded my system, the specs are in my sig. It all started with hard locks. No BSOD, just a hard lock at which point I would have to hold down the power button and restart. It's very random but is consistent when the system is pushed. However, sometimes it will take some time and sometimes it will happen quickly. Now it is getting to the point were it will just reboot. It has done this right after logging into Windows as well. Another new development is that I will get static through the speakers ocassionaly. Also, when messing with the BIOS it would not boot. It would post but Windows failed to load until I went back to fail safe defaults.
I've been trying to run Prime95 and I get this result:
[Sat Jan 16 23:36:04 2010]
FATAL ERROR: Resulting sum was 3.206511881782796e+016, expected: 4.764133057460626e+016
Hardware failure detected, consult stress.txt file.
FATAL ERROR: Resulting sum was -804318095685795, expected: 1.331283465043802e+016
When it does this it consitantly fails on worker 7 and 8. So, I am assuming that the fourth core is bunk. I've also run memtest86 three days straight on it with no failures. Here are some other solutions/conjecture I've gotten:
1. Reinstall Windows with a slower optical drive.
2. Memory is being undervolted, drive up the voltage. Which it is being undervolted by the auto settings.
3. Could be a northbridge issue.
I would be pretty confident that it's a CPU but the static through the speakers and the failures to boot after changes to the BIOS have me wondering. Also, I am not over clocking.
Any advice?
BTW: OS is Win7 x64 Pro.
Any advice?
